1 - 15 of 15 Posts
I don't know anything, but it seems to be a general trend that the 2 into 2's don't perform as well as the 2-1s, but the 2-2 do sound good, and some look really good.
yeah ive been told the same about the 2 into 1 set up i had the cfr now im going to try the bubs i hope there not as loud as the cfr was
I think those are the pipes that sillyboy has. If that is the case they are still fairly loud. You could try and contact him we put the stage 2 cams in his, and redracer has his with a cfr, we all went for a cruise. I was in front of them for the most part so I can't tell you which was louder, or if there was a real difference.
Wick
I have the Rinehart 2-2 they are loud I just use ear plugs. I am not an expert but I would say they would have to be better than the CFR because they dont stop level with your ears like some 2-1 do. I mainly chose mine because I didnt like the way the header pipes on 2-1 come forward and cover the engine.
'04 1300
Every true 2 into 2 made for the Revo motor loses HP over the stock exhaust.
Justpassinthru
They are Louder, and I can not feel lost of power at all, and tested a few new Vrods night rods in last two years with stock exhaust and they feel choked up a little and do not accelerate and breathe like mine with power. I have a pc-3 on it and dynotuned before I got it used .Yes ear plugs and full face used when riding.
well im am going to try to get the pipes on tonight the bad part is that the bike had the cfr on it when i bought it so now i have buy or make the stock exhaust bracket
without dyno results u guys r just wasting space. the 2n2 look n sound better. they r lighter and stundier also. why dont u take a bike and do a comparison at a dyno shop and give us the results
Discussion Starter · #11 ·
yeah im with you on the sound it sounds mean alot diffrent than the cfr as far as the power loss it might be a little less power down low but it seems like the bike pulls a litttle harder from the mid to top
Wick
Dyno results are just figures alot of the time you wont notice the difference on the road. I have buddies with 2-1 on there 1250 vrods and on the road both exhaust perform about the same. So each to there own get what YOU want.
:hidesbeh:
Mitch
That's exactly what i'm noticing for a difference too. From stock to the bubs I noticed the low end was not quite there. I lost my rolling burnouts. Then when I put the cfr on I got all my low end back and the top end pull of the bubs is not quite there.
1 - 15 of 15 Posts
