The right side front frame where the brake lever and foot peg are attached, broke. I need to fix or replace the frame. Bolts are already loose. Does anyone knows if I have to support the engine or the upper frame to remove the corner frame. Thanks in advance.
2" of dangling death
No support needed, just get a new one and unbolt the section and remove
V's and Z's
I removed my right side floorboard to install a new exhaust. The floorboard mounts thru the aft end of the frame section. To get the frame section bolted back up, I had to use a scissor jack so the bolt holes would line up.
