1 - 7 of 7 Posts
Because of this, hahaha
Brisk Premium Motorcycle Spark Plugs are unique spark plugs that are designed to
- increase horsepower,
- increase acceleration,
- improve throttle response,
- reduce emissions,
- improve fuel efficiency.
Brisk was founded in 1935 and collaborates with
Lamborghini
in their spark plug designs.
Autobanmod
Since Friday I'm using these because I had problems with mass electrodes being blown off the NGK Iridium plugs when going with full boost on the Autobahn:
http://www.briskracing.com/content/turbo.php
Engine runs a bit more rough in idle and at low loads but the rest is ok.
Edit:
You won't need them on a stock engine.
Multiple ground prongs are different from the ebay none / ring item and have been used on aircraft and as custom made plugs long before various companies started offering commercial versions.
On the ebay item; how does a copper electrod plug create three sparks per cycle?
Increase horsepower? Well, every new plug will increase horsepower and cause cleaner burning compared to a worn plug.
Shelby Stanga Rocks
Brisk Premium ZC is a spark plug that has no grounding electrode and provides three simultaneous sparks per one ignition impulse.
I took that right from the Brisk website. Now how can you have 3 at the same time. Well they have a picture of one sparking. It apears that you have seprate arcs durring the same pulse. The picture shows 2 but it may be able to produce 3. I think what they are calling a spark is really an arc. Just wonder how that would stress the coils and how it would effect the knock sensor ion.
It dose not apear to be like a MSD igniton where it will pulse the plug and you have several seprate spark impulses. This seems to have 3 arc trails per impulse. That dose seem like a good concept for a forced induction motor. I also see a whole learning curve with the tune up and plug read.
1 - 7 of 7 Posts
