Hi All,
So I've bought some Brembos to go on my 2003 VRSCA and I am replacing the brake lines.
  1. I picked this up for the front brake lines, Gafler steel braided. "HARLEY DAVIDSON 2006-2011 VRSCA / SCD / SCDX V-Rod / Night Rod / Special GALFER BRAIDED STAINLESS STEEL FRONT BRAKE LINE KIT"
  2. The new Brembos from a 2006 use DOT4 brake fluid since the old 2003 brakes used DOT5 what do I have to run through the system to flush it properly? I plan on using a vacuum pump, this will be my first two-wheeled brake mod.
  3. I am going to get the 3rd Brembo for the rear I have noticed the old brake lines go from rubber to a hard bracket and line mid bike. What's involved here to do this right?
  4. Is there anything else I might have missed so far?
Thanks for the help
Hi All,
Thanks for the help
Flush really well with denatured alcohol before you put any brake fluid in it, as the DOT 4 and DOT 5 do not mix well.
Both the later Brembo rear and the earlier rear calipers use a mixed rubber and steel pipe. The early pipe will fit onto the Brembo caliper but because the banjo is a slightly different angle to the banjo on the later pipe it touches the bracket slightly and needs a little tweaking. If you are not comfortable doing this may be better to replace pipe with the later one.
I assume you have the discs as well to go with these calipers as they are a slightly larger diameter. If you try to run the smaller discs the pad will not have full contact and you will end up with stepped pads which will result in a non functioning brake later on.
I haven't put all the parts together yet, rotors are on the hunt but I wasn't aware of the size difference, so thanks. I'm comfortable wrenching a lot, been doing it for decades on 4 but on 2 wheels, I'm a bit freaked out about removing the rear tire. I can do everything else, but the wheels are making me a bit antsy.
As for the rear brake line, I will go with the newer Brembo version. My old lines look pretty bad, its time...
