Would like to eliminate the rear brake pedal on my destroyer and run both brakes off of the front brake master cylinder, is it possible to run a tee fitting and split one to the front and one to the rear? Is it the same master cylinder they use to run the dual caliper set up on the V-Rods?
As for being able to do burnouts was thinking LineLock in front brake line. Thoughts, Concerns, Ideas?
Noel
not sure about other 2006 and newer models, but looking at my 2004 PM the 04's used a 11/16" bore MC
My Destroyer PM shows a 9/16" bore, you might have an issue active displacement tying two calipers to the 9/16 Master.
Are you concerned with VRD class issues, or running another more liberal class?
many sportbike stunt riders relocate their rear brake to the grips as well, but they do not splice off of one MC
:eek:fftopic: :eek:fftopic:
This section is for DESTROYER OWNERS and those who have experience with racing and working on them.
Go post somewhere else if you need to be heard.
Discussion Starter #5
Not worried about VRD Class, big feet and the location of the exhaust and brake don't go together to good.
