Just finished putting on braided throttle cables and water hoses. No big deal on the cables, probably the easiest set that I ever replaced. Everything is well placed and easy to get to. The water hoses on the other hand were a bear to get on, the hose in the back is almost unworkable. It took almost 45 minutes to get just this one piece on, if you work it just right you can rotate the front pipe forward just enough to let the back pipe lift up and allow the back hose to go on. Then you have to get the pipe back in place and try and force it in the hose. This is still not an easy task as there is little room to work. The front hose was no great shakes. the kit really dresses up the bike but for 90 bucks and a lot of elbow grease I'd suggest getting the chrome cover for the front hose and let it go at that. an alternative would be to replace the front hose and forget about the back hose since you can barely see it anyway.
