Here are some photos of the install thru completion of THE BOSS-NOSS System. As with all first time installs it took a total of about 4 hours including bottle painting. If I was to do another install it would take about 2 hours. After the install I thought I was ready to go, but I guess to my stupidity the bottle shipped empty, so I had to get it filled for $7.00 at a local speed shop. I also purchased a NOS gauge from them. After all was done I did a couple of test rides to tune the system and WOW it was well worth it what a jolt of power (40hp) delivered by 2-20hp nozzles. I was cruising down I80 in 5th gear hit the juice and it felt like I was in 3rd gear, so much so I tried to upshift to a gear that wasn't there. LOVE IT! A couple of install notes; when installing the frame part of the bottle clamp tighten the allen head screw closest to the radiator all the way tight leave the other one loose if you don't you will never be able to tighten the one closest to the radiator. Make sure the bottle portion of the clamp is real tight to the frame mount. I think the hardest part of the install was fishin the wires to the fuel injectors (leave the horn off the bike till the end) All in all I love the extra boost! ps the guage I added is only to tell me when I am empty.
