i bied new factory black levers ,but when i install the right brakelever my stoplight keeps on burning when i replace the old one then everything works ok what to do ???? to fix it
grtz wolf
Sounds like a defect in the lever. There is a switch that the lever contacts when pulled and it sounds like the lever is making the switch even when not pulled. This may also be a safety issue in that the lever may actually be making contact with the plunger for the brake master cylinder also.
maybe wrong levers
i think i found the problem , forhaps i have the wrong kit i have the kit 42275-05 but normally it should fit because it says fits all 2006 and later VRSCR models ,but now i see at genuine parts the nr 42275-07 could did make a difference ?
grtz
wolf
problem solved
i removed the all black paint from the inside of the lever now it works like it should be
thnx see ya
grtz
wolf
