You broke the clutch switch. Same p/n as the front brake switch.i put them on mine and lost the abillity too just pull in the clutch and start i have to be in nuetral , unless they got better ones in the last 2 or 3 years...
I would be real interseted to know how your paint job turns out. That would be a super cheap alternative to spending $360 for HD's black shifter, linkage and brake pedal.:broke:not really. pretty straightforward R&R job. have a bit of molydisulfide grease on hand though to lube the brake lever where the stock one is lubed (you'll see where when you remove it). careful with the screw on the bottom of the right switch housing (i had to loosen it to get the brake to slide over far enough). ended up dropping the darn thing into the radiator and had to take the back trim cover off to get the screw back.
much cheaper solution is to pull your stockers off, sand the anodizing off with some 80-grit, and shoot them with low-gloss black engine enamel. i'll be doing just that with my brake pedal, shift arm, and shift linkage next weekend.
how much that run ya? im thinking of doint the same.i just powdercoated all the stock pieces
:them:i just powdercoated all the stock pieces
i think for my headlight, handlebars,hand controls, shift peg, rear brake foot lever, and rear passenger peg extension arms and handgrips it came to like $100 or sohow much that run ya? im thinking of doint the same.
