Making the UK Fatter
:helpme: I have just returned my second Clarke (Machine Mart) bike lift in a week. Both of them pi**ed oil all over my garage floor and refused to lift. I was more than lucky that I never had a bike on it.
Need an alternative now. Any of you guys use one of these?
http://www.bikelift.com/harleys.htm
Regards
Regards
Order a Sears Craftsman!The Best Period for the Money! :kaz:
Regards
No but I have one from Hein Gericke. They have a picture of it in their latest catalogue (there's a copy with this month's Bike magazine) carrying a V Rod.
£99, very robust and low enough to fit under the V Rod when it's resting on the jiffy.
Christine
i,ve had the clarke lift for over a year now and it has never given me any bother.it would not have been a problem if your bike was on the lift as it locks in three different heights ,taking the pressure off the hydrolics when in the lift position :cheers: .if you tell them you have flagged them on this site you may get one for nothing. as it is bad publicity for them.
Your correct the bike would not go down, but the bike would be stuck raised off the ground because you have to lift it up a bit more before you can un-latch it.
I got the hein gericke catalogue but notice the lift is only rated at 300Kg, I suppose it should be OK, especially as they picture one.
Does it lock in position when raised?, the price is OK in this one, I'm just put off the hydraulic jacks at the moment.
Thanks for the advice
Petrolhead
I have had the 'Clarke' lift for 6 months and the bike stays on it whenever it is garaged, that has been most of the winter period and I have had NO problems at all.
The 'Clarke' lift is rated at 500Kgs
The 'Hein Gericke' lift does not look as robust and at 300Kg rating is not as strong, in fact it's extremely borderline with the V Rod on board.!
The V-Rod is factory rated at 596 lbs/270.34 Kg 'DRY' so factor in Fuel, Oil, Coolant, and some accessories and you are very likely over 300Kg.?
Worth the risk?
Not for me thanks!
The V-Rod is factory rated at 596 lbs which is 270.34 Kg 'DRY' so factor in Fuel, Oil, Coolant, and some accessories and you are very likely over 300Kg.?
Worth the risk?
Not for me thanks!
I have just sent a letter to Clarke & Machine Mart for now, and I was wondering about that 300Kg rating.
