1 - 2 of 2 Posts
my destroyer is creeping ahead at the starting line and red lighting me while i am in the 2-step. i have changed the clutch, bled the master cylinder, then rebuilt the master cylinder. would it be the button actuating the clutch? jerry
Noel
No, possibly the set up is not quite right, start with lighter static spring pressure. Also the weights at end of each arm might need lightening. What is your set point on the two step?
1 - 2 of 2 Posts
