Well should have known something was up when I went through 3/8" tank of gas in 40 miles,but it was runnig good.Well it was!!! Staerted slowing but wasn't letting off the gas.As soon as I let off the gas it died!I got it started and went to a lot.Re adjusted the fuel settings on the race tuner back to what they were with my CFR pipe.It idled,so I turnede around and headed home.Got about 4 miles down the road and died again.No idiot lights!!Then I tried starting it and it sounded like a dying battery,which I just replaced 3 weeks ago.Finally got it going again and made it 3 more miles then it shut down,Oil temp was 256 when I stopped.The fans stayed on for 20+ minutes! .I have a lil soot on the end of the pipe,so I'm guessing it was rich.I also fixed a leaking water pump cover gasket yesterday.I bled the air out afterwards and everything.Should have left the leaking one in!!!Anyone have any clue as to what the heck I did??? Really sucks because I never had any kind of problem with thie bike til then.Anyone with any race fueler setting for a topless, Reinhart 2:1 pipe that I could use.
DuPage County
Sounds like you had some trapped air in the cooling system and it WAY overheated.
It may be damaged internally.
NOT A REAL HD RIDER
That's really odd...I just put on a new pciii with a new map and my bike is doing somthing similar....and it turned my pipe Blue at the 2 into 1 area of my cfr...Im assuming from heat....and it looks like its burning oil around over 5k...
V's and Z's
lean?
It started when it cooled down.I'm going to check the coolant and re-bleed the system.Not sure it was lean.I was thinking rich myself.Have some soot build up on the pipe and was watching the gas gauge move as I was driving.Need to either get a setting for the race fueler or get a power commander.
NOT A REAL HD RIDER
Honestly Z I think it's too rich and running hot.....my CFR turned blue it was soo hot.....Im a little puzzled to be honest...Im going to reload the 020 map and go from there....I need to check my plugs too and see what they look like....
I checked my coolant today and guess what.The cover I made for the filter(had to cut the stacks down to fit the JE airbox on)was off,so I'm thinking it came off when I was riding and maybe that could have been my problem.I only went about 3 miles before I shut it down completely and waited for pick up.If the cover came off that would make me go lean,right?It started back up today and sounded ok,how would I know if I really screwed anything up.I was only going about 40 MPH for about 3 miles,so I hope I didn't realy damage anything.Even though a 1340 BB would be nice
NOT A REAL HD RIDER
If you had warping inside anywhere you'd know it...it would sound like complete garbage and if it ran it would be a very uneven sound
