1 - 13 of 13 Posts
I just had my bike into the dealer about a month ago to have everything changed out to chrome. I also had the rear brake caliper chromed. Since then I drive my bike for about 30 miles and the belt comes loose. Does anyone know what the problem is? Is it the dealer?
When you say the belt comes loose, are you saying that it starts to flap?
Yes, I starts to hit the guards. I never had that problem before. Just after Longhorn changed everything out for me. Also, looking for a "GOOD" V-Rod mechanic in the DFW area.
yellowcat2000 if the belt is hitting the belt guard especially in high gear at low rpm then I would guess that they did not get your belt set at the proper amount of tension.
Max
Greg/Moderator
Had the same porblem with mine I complaind about it during my 1000 mile check up. On the way home still had the same problem, belt hitting lower belt guard in high gears. I put the bike on the lift and snug it up untill the problem was gone, it might take a couple of tries but it can be fixed [ make sure that the axle is square in the swing arm this is critical so the bike doesn't pull]. This is not a tough fix if you dont have the chrome axles covers on, if so it will take a little more work but well worth your effort. Good luck and take your time and make sure everything is tight.
Get a Chain!:icon_twis;)
DuPage County
Even at the proper tension, the belt can still hit the guards, especially when lugging it in 4th or 5th.
Don't lug it I guess.
C
1 - 13 of 13 Posts
