Well, I bit the hook and bought the basket case 2009 VRSCAW listed in the classified section. Got it home a couple of weeks ago and started going through everything to see what new parts were needed and what was missing. The biggest issue so far is that Harley is not supporting the older bikes and no piston and ring kits are available for the 2002 motor in this bike. I was saved by Andy, Coastrider on this forum, and a new piston,rings sleeves kit is enroute from Spain, thanks again Andy. The bike is slowly going back together, replaced bad bearing in the rear sprocket, bearing in the swing arm, new fuel tank and used fuel tank innerds, new foot peg clevis for both sides, and lots of small parts. On the engine I replaced all the transmission parts with a complete 2004 setup I had on hand, purchased a new fuel pump as the old one was pretty heavily scored on the rotors, and put new valve seals on all 8 valves. I'll keep this thread updated as I go.
Sent from my iPad using Tapatalk
