WHATEVER
I need good starting MAP for twin cam 95CI with thunderheader, any body?
RICK
What Pistons And Cams Are You Using. What Version Of The Rt- And Also, What Year Of Bike?
RICK
I Have Several Maps For Various Combos I've Done In My Shop. If It Is Just A Base 95 With 203 Cams And No Headwork, Use The Factory Map Stored In Your Race Tuner From Harley. I Can Give You The Number If Needed. If There Are Other Mods, I'll Match It To One Of My Maps. If You Use The Base Map, You Wont Have To Change Any Of The Timing, Just A Little Of The Afr Table, Mainly The 80 And 100 Columns
WHATEVER
2006 Dyna. It is the 1550 wit the SE HTTC Heads, PRO HTTC High compresion pistons SE 203 Cam,
RICK
Let Me Start Going Through My Computer And See If I Can Find One That Matches Close. It May Take Me A Little Time.(tonight)-i'll Repost Tomorrow
RICK
dthdoc
I Don't Have A Good Map For The Htcc Heads On A 95". Everything Is 103 To 124 With A Lot Larger Set Of Cams. I'm Searching A Couple Places For A Similar Set Up. Most People That Spend That Much Money In Heads Up The Cam Quite A Bit. Hold Tight, I'm Still Looking!
