1 - 7 of 7 Posts
Looking through the Parts Catalog I noticed that there are 2 different part numbers for the Auxiliary Volume (center section of the exhaust system) Domestic part # is 65151-01 and HD International part # is 64929-01. Does anyone know what the difference is? I have spare ones of each type but after looking at them I can't see what the difference is.
GT - UK
Making the UK Fatter
probably the CATs, my middle bit has some kind of honeycomb inserts in one end, which I assume is the Cat converters.
Mr-vrodder is correct, I think some of the exports have cats in the center section. Since the main ingredient of a cat is palladium I think a quick price check would verify that since it is a little more expensive per ounce then gold is.
Discussion Starter #4
Yep, your right. These photos are looking into the exit end of the center exhaust section on a UK bike. The equivalent USA part is empty. There is no legal requirement in the UK for a catalysed exhaust - if that is what it is. The "mesh" only seems to be about an inch deep.
GT - UK
Jamie
Max and Mr-Vrodder are correct, the difference is two 1/2 cats added at the end of the 3rd Volume (center section). There is no performance loss associated with the different parts.
I have the 16g SE pipes fitted from new, I don't think they have the Cats, although I have not checked.
max, what the heck is palladium??
Palladium and Platinum are the two main ingredients of the catalyst. They reduce the unburned hydrocarbons and carbon monoxide by burning (oxidizing) them over a platinum and palladium catalyst. This catalyst aids the reaction of the CO and hydrocarbons with the remaining oxygen in the exhaust gas.
And for the most part the catalyst that I work with these days are so efficient that they cause almost no performance loss at all but you still see people butcher them. If you ever compared a good one and a bad one on a 5 gas machine believe me if you ever get tested there is no fooling the machine.
Max
1 - 7 of 7 Posts
