I need to get an opinion on Progressive 412's. Are they a lot better or just a little better than stock HD shocks? Are 440's worth the extra cost?
Thanks
Thanks
:them: Couldn't have said it better.akjitsu said:The 440's, along with fork springs and SE oil, will transform your V. You'll wonder how you ever survived the POS stock suspension.
rjrivero said:I run the 440's an I think they are a great fit for the V-Rod. Good dampening on compression and rebound. Much nicer ride. :2cents:
V-Fred said:440's and front springs and HD oil. Yes, a thousand times yes. Best mod I have made, after the open wheels.
:them:NightMare said::them: Couldn't have said it better.
I put Works Performance shocks on but like others have said, HUGE difference. I think any of the mainstream performance shocks will make a big difference in ride comfort and damping as long as the springs selected are correct for the application.Soundhound said:I need to get an opinion on Progressive 412's. Are they a lot better or just a little better than stock HD shocks? Are 440's worth the extra cost?
Thanks
I went with the 412's too - they are only about 2bills and made differnce but I do not know how they compare to the 440's.:moped:coinpurse said:I love my 412's, I haven't ridden a bike with 440's, even with a 1 inch shorter than stock. I have not bottomed out, even with the lady on the back.
Did you go stock length or shortened?rjrivero said:I run the 440's an I think they are a great fit for the V-Rod. Good dampening on compression and rebound. Much nicer ride. :2cents:
Not sure what RJ did but dropping 1" common. That's whatIi did based on forum member advice.Jim J said:Did you go stock length or shortened?
Dan - got mine here. 12" 412's - have never seen 11.75". I cannot say the 440's aren't the way to go but like others, I am pleased as punch with the 412's.NOS-DAN said:I was considering having my stockers cut,but now after reading this...it sounds like many think the stock shocks arent very good....440s are abit more then I wanted to spend...
so the 412s are a good upgrade too it sounds like....can someone please tell me,where is cheap place to finde 412s,and I also want to lower the back down as much as possible,but still ride the OCCASIONAL passenger....would 11.75 be too low?....do they come in 11.75?
thanks gang!
Dan
440's are rear and heres a link for the front kitchunk said:forgive my stupidity here......... so the 440's are the rear shocks then? what do you do to the fronts?
