1 - 7 of 7 Posts
Hi All,
I’m wondering if anyone has had any experience with the bike stalling or cutting out when the engine goes from high RPM range to low (ie: fast downshifting, stopping, etc)?
Its happened to me a few times this weekend, on a couple of occasions where I was slowing down to approach a red light – bike turns right back on once I hit the ignition.
Any ideas?
james
do you get the tilt code while your breaking heavily... i can't remember what it is call but i noticed the bike cut off when i layed mine down in the wet grass... it happen while it was in neutral i got a code stood the bike back up turned switch off then restarted it.
Kickstart My Heart!!
So you are running stock exhaust? How long have you had the bike, when did this start happening? Any changes prior to the problem appearing?
Are you loosing power when the bike cuts out i.e. the instrument cluster goes out too or does the bikes electrics stay on?
bcrichard
clean the IAC (or replace if it's defective). I had the same problem, some spray carb cleaner fixed it.
(IAC = idle air control located between the throttle bodies)
1 - 7 of 7 Posts
