1 - 20 of 29 Posts
I'm sure they're on there for some safety reg, but they're just on there with foam adhesive backing... very easy to remove.
I was thinking about taking mine off to clean the bike up a little...
What do you think, any of you take yours off yet?
Yes, just becareful you do not use anything sharp or you will scrape the hell out of the forks. I used a hairdryer and a plactic spoon. Then used a lttle WD-40 to get off any remaining adhesive.
Scott
Definately fishing line!!! On the tank emblem too if you want.
CEMIRT Lifer
Removing Reflectors from Front Fork
LIUNARep said:
Heat gun and run some fishing line or dental floss behind em.
Ditto...did the same. Followed-up with WD-40 to loosen and remove adhesive.
FireBum
:them: A hair dryer may be safer in the hands of a novice. The fishing line alone will do the job.
Gotta Blast!
Time was, that removing your front fork reflectors was part of the initiation around this forum... of course some guys have to be rebels, right RJ?
p.s. Look at Nightmare's bike on the front page for more evidence.
FireBum
PeytonVRSCD said:
what about dental floss?
The dental floss will likely break if you don't heat the metal around the reflector to soften the adhesive. Fishing line is stronger and thinner so it cuts better.
1130cc.comaholic
I pulled mine off with my hands and used my thumb to take off the glue residue :thumb:
I FINALLY GOT BOOST!
Same here!
The wife's hair dryer worked for me (just don't tell her). I tried fishing line, but cut the hell out of my pinkies...
If you get the adhesive hot enough, no fishing lin eis necessary.
tincup78 said:
:them: +1.
:them: +2
Gotta get those ugly things off your bike ASAP.
Another Ski season
Going to Montana to raise some.
VRF0RUMS ORIGINAL
I wouldn't do it... it'll void your H-D warranty.
:hidesbeh:
You know, someone was looking for some reflectors a while back... :hidesbeh:
Ducking for cover!
Anything that will increase my visibility ima keep on the bike! Call me a rebel. :D
Freedom Isn't Free
Texas V-Rod,
If you are concerned about visibility, why buy the baddest, blackest bike available?
Lots of wild paint and shiny chrome out there.
1 - 20 of 29 Posts
