1 - 2 of 2 Posts
Hi,
Have had the cams in my bike now for about 2k Kms and havent really found the changes that ive expected which have come from other bikes that have them but different tuner. Is there any changes anyone would recommend to the maps or parameters ? If i was to compare it to before the cams id say its only just better.
Should i go with a screamin eagle tuner and dyno or can i get the same out of the gen4 DTT ?
Cheers
the dtt works well with the se2 cams but in retrospect for street use i found the se2 cams to be a backward step,they are noisy,guzzle gass and loose some low end punch to gain minimal top end when winding to red line only.i simply got sick of them,went back to stock ,flowed the heads and with the aid of the dtt actually improved the streetability to be better overall.in early engines the late model oil pump helps more than the cams.inmo,dont waste your money and engine on these se2 cams.
1 - 2 of 2 Posts
