1 - 2 of 2 Posts
I have a high pitched squeak at idle after the bike is warmed up. It seems to be originating from the right side of the bike and its really annoying but I can't think of what would make that kind of noise....
Buy American!
If it doesn't change when you pull in the clutch or press on the muffler heat shields, it might be your water pump. Click here.
There is a thread here about the water pump drive shaft bolt coming loose and causing damage, but I think that is a problem on the left side. You may want to search for the thread just in case.
1 - 2 of 2 Posts
