1 - 13 of 13 Posts
Killer Service Inc.
:hidesbeh:
What you do?
you get anything in the mail yet.
Voluptuous 'V'
Basically, I was attempting to inspect/clean the IAC motor while I had good access and the most forward screw head broke. After sever hours of using Vice-grips, spraying lubricants, heating, drilling, easy-outing (yeah right) the screw hole split in several places.
Voluptuous 'V'
If you can't get one easy and cheap.Get the ferrous broken screw out and fill the hole with aluminum at a shop using a heli arc.Around here,this would cost about $15.
Then drill and tap a new hole.
Hopefully, someone has one laying around that wants to part with it for a reasonable amount of cash and your idea may be my 2nd best option.
Pat (Patrick!)
Do an 1130cc and a 1250cc use the same throttle bodies?
Pat (Patrick!)
HoneyB,
Don't have a clue...Khaib may have something for me....at least the part number (27657-01) is for the 1130cc.
Thank you just the same.
I don't have an extra one. I just noticed that Khaib has a 1250cc motor, and you don't.
I was just looking for some clarification.
Voluptuous 'V'
Discussion Starter · #11 ·
I understand..
As long as the part number matches... it should be good to go. My parts manual calls out 27657-01 for the throttle body. Don't know if they need different tweaking for different motor sizes. Someone else on the forum may know this answer...
Thanks for the input/clarification.
1 - 13 of 13 Posts
