For my '07 AW, I'm looking to do mid-pegs only for an alternative to front pegs on long rides. The right side looks easy as the OEM right side foot rest bracket for the R model should bolt right up with a longer bolt and a spacer.
The left side is another story. See picture of the bolt hole locations on my '07's lower left frame. These holes are not in the same configuration as the R model, so using that bracket is out. I have no idea what if anything is intended for these holes. They have plastic plugs inserted into them. Does anyone know of a mid-peg bracket that can use these holes on the AW? The bracket only, as I don't intend to buy a Kosman kit only for this bracket.
If I have to, I will fab one up but thought I'd check with the Forum before going that route.
