fellas,
from what i've gathered on previous posts...
(i've got a stock '07 AW, domestic) am i right that my pulley is 28t,
that my belt is 149t, and that the stock belt will work w/ the 26t front pulley?
also, sam @ turbotec says my stock
front pulley cover will still fit w/ their 26t pulley, w/o modification, correct?
lastly, i forgot to ask sam if the grinding is still necessary of their pulley
for proper fit or if that's been resolved. any '07 owners been thru this yet? thanks.
I don't think any dimensions have changed in this area from 06, you'll have to grind the cover behind the pulley or if you have access to a lathe open the inside of the pulley up. Its about .030"
I put mine on in 30 min with no grinding. Was it a fluke. It seems everyone else has had to grind it a bit. 07 DX.
exterminator said:
does 2 teeth really make a diff? i know on dirt bikes it did but they only had 19 or so.
Big difference off the line. Not so much when your going 50mph.
