1 - 3 of 3 Posts
That has trouble with my headlight wires breaking from flexing? The wires
exit the left side cover and when you turn the handle bars back and forth
they kink and over time will lose continuity. I see no other way to route the
wires.
Any input would be apprecited.
Thanks,Floyd
Floyd I drilled a hole in the back of my headlight housing and zip tied all the wires down tight to the headlight to keep them from dragging on the steering stem lock. Never had them break but I saw it as a possible problem long ago and made the change on mine.
Thanks Max, I'll have to take a better look at this when I install the new harness. My problem is where it exits the side cover, there has to be some
slack thier when you turn to the right, but then when you turn to the left it
wants to kink at the point.
Floyd
1 - 3 of 3 Posts
