1 - 14 of 14 Posts
F*@kTard
Seems this year/model is the bastard of the RHSC club as far as aftermarket headlights go. Anyone with an '05 B been successful in mounting different headlights?
Dilligaf
You can mount any v-rod light on the B, you can use the A or the Billet HD light.
F*@kTard
Ah, that's right. Its the trim visors that don't work. I had it stuck in my head that putting a different style light was going to be a PITA.
Dilligaf
All the mounts are the same between the A,B,D & SE models. The only thing that is different are the handlebar risers for the different models.
F*@kTard
There must be something different about the 05 B. All the HD visor accessories say they fit every VRSC but the 05 B.
EXCELSIOR
The 05 B uses a Sportster type lamp assembly with an old school teardrop small bezel, 5 3/4", lamp hung from the mounting cowl. The others, except for the D/DX, use the 3D lamp with mounting ears on each side.
The mounting bolt pattern on the front of top tree are the same but the mounts are different.
The 04 B like I have uses the 3D type lamp assembly.
Dilligaf
The only difference is the add on visors ie. round headlight versus oblong headlight. Sorry, I thought you were talking about headlights not visors.
Dilligaf
daif1966 said:
is that a HD light and cowl I would like to put that on my AW
You can install a nightrod setup on your aw.
if were talking about visors, I put on a visor trim ring without any problems
Lifetime Member
Going from the one bulb to the two bulb or vice versa only requires a jumper harness, about 15 bucks from the MOCO.
1 - 14 of 14 Posts
