1 - 1 of 1 Posts
I have always thought the rear brake pedal was positioned too high for easy use. There are a few threads on the forum with a fix involving re drilling the ferule which holds the lever (probably a poor explanation).
A good friend (McGuyver type) who does work on several of my bikes had a ,to him, simpler fix.
He put a large crescent wrench on the pedal and then heated the cast aluminum pedal with a butane torch (the $5 or so canisters you get at the hardware store). Wrapped a wet rag aroung the area so as not to burn anything.
Appied gentle pressure untill the pedal bent down an inch or so.:D
1 - 1 of 1 Posts
