All New Bike Of the Year Contest: PT#11: "Custom"
  • #1 Scott F. Greenville, OH. 2002 VRSCA
    Votes: 36 23.4%
  • #2 Frank C. Longview, TX. 2006 VRSCD
    Votes: 46 29.9%
  • #3 Greyson W. Burlington, NJ. 2004 VRSCB
    Votes: 5 3.2%
  • #4 Matthew M. Pocatello, IA. 2006 VRSCD
    Votes: 1 0.6%
  • #5 Bryan P. Coventry, RI. 2003 VRSCA
    Votes: 4 2.6%
  • #6 Bryan P. Coventry, RI 2002 VRSCA
    Votes: 2 1.3%
  • #7 Ethan B. Myrtle Beach, SC. 2006 VRSCE2
    Votes: 23 14.9%
  • #8 Shea G. Westchester, NY. 2006 VRSCD
    Votes: 9 5.8%
  • #9 Rolf S. Germany. 2004 VRSCB
    Votes: 14 9.1%
  • #10 Rob C. Alberta, Canada. 2007 VRSCDX
    Votes: 0 0.0%
  • #11 Alastair L. Victoria, Australia. 06 VRSCA
    Votes: 6 3.9%
  • #12 Sante G. San Marino. 2007 VRSCX
    Votes: 4 2.6%
  • #13 Konstantinos P. Greece. 2008 VRSCDX
    Votes: 2 1.3%
  • #14 Nigel M. New Jersey. 2006 VRSCD
    Votes: 2 1.3%
1 - 20 of 54 Posts
Sanctimonious
The 11th and Final Chapter of the much anticipated Bike of the Year contest is Upon us!!!
As noted in the Rules, Julyis designated to Custom Bikes. So look over the picts and choose the one you love the most to help that Member become the Bike of this Month and than in the running for The Bike Of The Year!
Good Luck to all!!!
A word to the wise is infuriating.
-Hunter S. Thompson
-Designed and machined in house where the custom wheels with obviously 3-leaf clovers in them. Front 19 x 3 and the rear 18 x 8.5.
-Built in house Drag bar/ with new controls and Joker bar end mirrors.
-6 piston single side front brake caliper
-1302cc motor built in house, with custom 1mm oversize valve head work, head studs, Jones cams, our 58mm throttle body, CP Pistons, Destroyer crank, our engine brace, VH 2nd gear and shift shaft.
-1130 cases where bored to 1250 in house.
-Custom made head badges
-Our own 26T Steel Pulley
-Bub 7 2-1 exhaust
-Drive side rear brake which was custom designed and made in house. This setup has never been done on a VRod in the US.
-4 piston rear caliper
-Arnott rear air ride w Frank front fork slam kit
-Digital Guard Dog keyless start
- Docs Taillight w/ custom rear LED relocation turn signals.
-Side mount license plate designed and machined in house.
-Rick’s 5 gallon gas tank.
-CFR seat
-Pondo custom machine side cover and swing arm pivot shaft covers.
-Other than that what was not chrome was dipped from the swing arm to the front forks.
Custom features and upgrades:
Paint and Airbrush Artwork By:
Johnny Edwards and Bruce Fix
Longview, Texas
Finish using House of Kolors and Dupont products
Base color Black Diamond on frame and bodywork, with Pure Jade Chromalusion flames
Custom stretched, widened, carbon fiber coated mono swingarm
Custom powder coated billet rear shock mounts
Dual shift control linkage
Custom dual hydraulic rear brake setup
Custom in-fork front air suspension
Rear air-ride mono-shock (Biker Buddy Pro)
On-board chrome air compressor
Custom microprocessor controlled dual zone automatic ride controller
Custom automatic retractable center stand
Custom keyless ignition and ride selector
Custom 13” steel rear fender
Franklin Designs Thorn front fender
Franklin Designs Wicked airbox cover
Custom recessed LED taillight and blinkers (Custom Dynamics)
Custom (real) Crocodile seat (CFR pan) (Action Upholstery)
Customized Roadster fairing (Rifle)
Custom powder coated billet headlight and fairing mounts
Diamond-Cut head fins (Diamond Heads)
Chrome engine covers (Harley Davidson)
Polished stainless steel fasteners throughout (Diamond Engineering)
Fat cat full exhaust system (D&D)
Chrome coolant hose cover (Harley Davidson)
Black hand levers (Harley Davidson)
Black powder coated lower fork legs
Black powder coated triple trees
‘B model powder coated drag bars (V-Mod)
Black powder coated customized belt guard
Dual driver and passenger Black Twister pegs and shifter (Arlen Ness)
Black Twister grips (Arlen Ness)
Convex LED turn signal mirrors (inverted) (Kuryakyn)
19”x3.5” chrome Monaco front wheel (Performance Machine)
18”x10.5” chrome Monaco rear wheel (Performance Machine)
Custom narrow (1”) chrome Monaco 78 tooth rear pulley (Performance Machine)
Chrome cush drive adapter (Performance Machine)
Custom 1” by 156-tooth carbon fiber drive belt (Gates)
Venom 120/70/ZR19 front tire (Avon)
Venom 300/35/R18 rear tire (Avon)
Dual 11.5” Monaco front brake rotors (Performance Machine)
11.5” Monaco rear brake rotor (Performance Machine)
Chrome Brembo brake covers (Harley Davidson)
Custom billet license frame and inspection holder
Custom fiberglass fuel cell (Zeel Design)
Chrome side covers (Harley Davidson)
Front radiator scoop (Harley Davidson)
Smoke tinted custom stainless steel hydraulic lines (Russell)
Black Pearl stainless steel throttle cables (Magnum)
Offset front pulley w/ outside bearing support (Ricks)
Complete air-box trim
IAT sensor relocate (Harley Davidson)
Chrome front and rear axle covers (Harley Davidson)
Race Tuner ECU management (Harley Davidson)
04 B with the following mods-
Lots of Pondo covers done Old No 7 Style
Pondo rear pulley slightly modified
Heavycycles taillight
ZBars internally wired by yours truly
Aftermarket hand controls
ZBars carefully dremeled by yours truly, taking about 4hours total to get aftermarket controls to fit. It sucked to do but was worth it
Kosman widened rear
240 conversion
Agoura seat
Air ride with remote capability to lower & raise
Custom Dynamics fork turn signals & LED's
Progressive lowering front springs
V Gage
Joker bar end mirror single side only
CFR Pipe
Flush front axle kit courtesy of Sewerat
Harley factory limited paint
While I didn't make these parts I picked what I felt made the bike flow best. All parts were installed and modified as needed or wanted by me.
Matt is From IDAHO (ID) not from Iowa (IA) like it says in the contest.
Featured as the "Cherry-bomb V-rod" at Arizona Bike Week 2007 by Brian Klock (Klock Werks) and Willie G Davidson
· Pinstripe Paintjob by Tex McDorman
· Custom Metal Fabrication on grill, fairing, belt cover, brakes
Custom Front Fender
Custom Side covers
· Modified Arlen Ness Fairing
Willie G Sig on air cover
· iPod Docking station w/USB, throttle-mounted volume control & Speakers
· Bar-end Signals
· Forward Controls with front frame adjustment
Mid-pegs
· Rick's Gas Tank 5.4 gallon
· High Performance Cherry Bomb Glass Pack Exhaust treated with high-heat ceramic
· Swing arm caps
· H-D Saddle Bags w/custom detachable mounts
· H-D LED Rear Taillight
· Backrest
· Luggage rack
Black Fork bottoms
· Upgraded Side covers
· Chrome lower belt guard
· Wheel upgrade
· Chrome engine kit
Sanctimonious
Discussion Starter #2
I have nicknamed this bike the "Forum Flyer" because most of the parts were purchased, traded, or donated from forum members. Here is the description:
'03 VRSCA purchased from Harleynurse in '08
V&H exhaust custom modified by CMASHARK
H-D Billet collection covers and caps
Chrome PM wheels
Chrome aftermarket Brembo true floating brakes
Chrome frontend and swingarm
Corbin Bags, seats, and fairing
LED directionals with smoked lenses
Arnott air ride
Racetech front lowering springs
Joker bar-end mirrors
#6 Bryan P. Coventry, RI. 2002 VRSCA
This bike is equipped with lots of custom/bolt-on parts along with some one off hand made stuff. Here is a description:
1550 Big bore
V&H exhaust
Custom handlebars with Joker Machine bar-end mirrors and a Raptor shift light w/custom mount to blend into A model clamshell
Black chrome Buell wheel conversion
Custom ghost flame paint w/frame painted to match
Kosman struts
Powdercoating by Tyson
Heavycycles stage II V tailight
Eurocomponents plate mount
Chopped rear fender and custom solo seat.
Customized TS supercharger and intercooler (with fiberglass airbox scoop)
Custom paint and pin striping
Custom nitrous system
Front and rear air ride
Exotic Chopper pipes and custom made heat shields
Custom made cylinder covers
Vance and Hines speed shifter
1 1/2" riser with drag bars and bar end mirrors
LED turn signals front and rear
Side mount licence plate
A few others I can't remember...
Trask Intercooled Turbo, Carbon Fiber Wheels 8.5" Rear / 21" Front, CFR Seat, CFR Swingarm, Speigeler Brake/Clutch Lines, QTMI 12.6" Brembo Full Floating Front Brakes with Brembo Goldline 4pot/4pad calipers & Matching Rear Brakes, Arnotts, Joker Machine Style King Hand Controls, Ricks Tank, Rizoma Triple Trees, Bob Dron Mini Fairing, Headwinds 7" HID Headlight, Copper Plated Drag Bars with Internal wiring, 530 Drive Chain Conversion 20T/50T, Performance Machine Foward Controls, Custom Front Fender, All Titanium Hardware, CRG Lane Splitter Mirrors and various odds & ends etc.
I custom fitted the Wheels, Brakes, Fairing/Headlight, Chain Conversion, Front Fender, and Titanium Hardware. Custom or not this is it, All Mine and barely HD anymore.
Sanctimonious
Brand name: HARLEY DAVIDSON
Model name: VROD / VRSCB
Production year: 2004
Registration year: 2005
Reconstruction: 2005 - 2010 / changed continuously
Owner & Builder: ROLF S
HD - Ident. no.: 5HD1HBZ104K803879
Admission: HU - 88 XX
Engine: HD - Evolution / Injection
Cubic capacity: 1131ccm
Tuning, software: Screamin Eagle & Power Commander modified
Clutch, lines Screamin Eagle, performance slipper clutch & Goodridge equipment
Electronics: Moto Gadget, gear indicator, r.p.m. counter, shift light, additionally modified cable connections
Air box, inside: DIY, flatten, modified, K&N air filter, transparent plastic plate
Air box cover: HD & Violator, made of aluminum, flatten with integral tachometer part, chrome scale, clued
Aluminum air inlet welted tubes, stainless steel perforated stripe incl. side fins, polished, screwed
Coolant hose: DIY, aluminum, stainless steel perforated design, polished,
Side covers: HD & DIY, stainless steel perforated design, polished, glued
Logo, skull: Fritz Schneider & DIY, stainless steel, polished, glued
Radiator, spoiler: NLC & DIY, front winker inlets, stainless steel perforated inlets, polished, screwed, glued
Starter: HD & DIY, housing, stainless steel perforated design, polished, glued
Regulator cover: HD & DIY, black denim, stainless steel perforated design, polished, glued
Alternator cover: HD & DIY, circular adapted as well as stainless steel perforated design, polished, glued
Clutch cover: HD & DIY, circular adapted as well as stainless steel perforated design, polished, glued
Exhaust: KessTech, electr.-controlled sound management, 3 variable settings, race & esm & quiet, TÜV
Pipes, muffler: DIY & Corvette pipes converted, black ceramic coated, catalytic converter & muffler removed
Heat shields, end caps: HD & DIY, perforated, electronic adjustable stainless steel rods, aluminum end caps, chrome plated
Suspension: Legend air, electric air compressor suspension system, air pressure indicator
Suspension security: Teflon security buffers precaution stop, aluminum perforated conically shock absorber tubes
Frame: HD, reduced, rear cut, modified, paint HD-black denim
Drive sprocket: Ricks, bearing support plate & 30-teeth offset pulley
Pulley cover: HD & DIY, aluminum, stainless steel perforated design, polished, glued
Rear axle covers: HD & DIY, perforated design, chrome plated
Pivot bolt covers: DIY, aluminum with stainless steel perforated design, polished, glued
Swing arm: HD & Ricks & DIY, widening xxl, stainless steel perforated design, polished, glued
Belt guard: Ricks & DIY, short cut, stainless steel perforated design, polished
Pulley: RRC & DIY, aluminum perforated, stainless steel skull design, polished, glued
Fork: HD, Progressive Suspension, specialty oil, stem covers, stainless steel perforated design
Fork yoke triple tree: Rizoma & DIY, aluminum perforated adjusted angle covers, polished, screwed
Fork brace: Screamin Eagle & DIY, modified, aluminum perforated design, polished
Fork axle nut covers: Rizoma & DIY, aluminum perforated design, stainless steel perforated caps,
Front wheel: CNC-custom-made, 3.5 x 19, tire = 120/19 Metzeler
Ricks / Walz-Rodder, 3-piece screwed, black powder coated, perforated stripes polished
Rear wheel: CNC-custom-made, 10 x 18, tire = 300/18 Metzeler
Brake lines: Goodridge & DIY, modified distribution bridge
Brake pedal: HD & DIY pedal cut, Arlen Ness Battistini, perforated design, chrome plated
Brake rotors: Ricks / Walz-Rodder, perforated stainless steel design, modified, polished
Brake cylinder: HD & DIY, perforated stainless steel design, chrome plated
Footrests, front: Arlen Ness Battistini, perforated design, chrome plated
Shifter pedal: HD & DIY, Arlen Ness Battistini, perforated design, chrome plated
Shifter rod: DIY, aluminum perforated design, chrome plated
Control handle: DIY, short cut, perforated design, polished
Rear fender: Violator & DIY, made of steel, welted curved tubes, stainless steel perforated stripe, screwed
Front fender: Violator & DIY, made of steel, stainless steel perforated stripe incl. side fins, polished, screwed
Handle bars: V-Team, 850 mm stainless steel, stainless steel perforated design, polished
Front indicator: 2x Bullet blinker LED's, components integral in radiator cover body, glued
Rear indicator: 2x Bullet blinker & 2x rear lights/stoplights LED's, components integral in rear fender body, glued
License plate holder: DIY, Radiantz LED lights, aluminum perforated design, polished, glued
Mirror: Rebuffini & DIY, arms perforated design, polished
Hand grips: Arlen Ness Battistini, modified, perforated design, chrome plated
Lever handles: HD & DIY, short cut, perforated design, polished
Fittings: DIY & HD, oil temperature gauge, stainless steel perforated design, polished, glued
Lamp housing: HD & self-development, stainless steel perforated design, polished, screwed, glued
Lights: 2x 50 mm ellipsoid headlights, with aperture in low & high beam, 2x LED´s parking lights
Headlight bracket: HD & DIY, aluminum perforated design, polished
Horn cover: HD & DIY, perforated design, chrome plated
Seat base plate: Fiber glass, latching & lockable, screwed, clued
Seat cover: Imitation leather, glued, stainless steel perforated stripe, polished, screwed
Paint colors: HD, black denim
Applications, other: DIY-custom templates, perforated stainless steel designs, too much to list all!
HogPro swingarm kit with 300mm rear tire and Torque 5 wheels, Bub 7, 2-1 exhaust, Rizoma handlebars with Performance Machine grips and Joker Machine mirrors, Arnott rear shocks and Progressive front springs, Franklins Wicked air box cover, Radiator screens, Flush mount front axle, front fork covers and boots, lowered headlight, reshaped passenger seat, and a bunch of powder coating.
240 renagade newport wheels
custom made FLEX rear fender
reversed front fender
saddleman profiler custom made to fit rear fender
breathless performance air box
1" 3/4 burleigh bars
braided throttle cables
chrome tear drop mirrors
powerline exhaust
arnotts air suspension
arnotts air pressure gauge
4" 1/4 vampire headlight with custom made mounting bracket
kuryakyn stiletto foot pegs
all hand controlls chromed and front forks and lots of other items
So what did I do to her, I gotta look at the bike cause i cant remember it all.
UP FRONT
1. Tommasso motocross handlebars with inbar wiring with Motogadget's cool and easy to reach pushbuttons.
2. Spleigler's clutch and brake hand controls carved out of a block of Aluminum, and fully adjustable.
3.Euroracing's duel throttle cable rapid gas system.
4. Kellermans micro led front indicators which i fabricated into the bolts that hold and adjust the front headlight.
5. Rizoma's old style triple trees with racetech springs and such in the tubes.
IN THE MIDDLE
1. H n' D's Stage II Cams
2. The heads done by Vance n' Hines with oversized valve for future abuse.
3. 58mm throttle bodies done by Fitzgeralds.
4. Diamond cut heads by Fitzgeralds
5. BUB 7' 2 to 1 exhaust
BEHIND ME
1. Hard-tail type rear fender which i cut and bolted on the swing-arm with 2 staffs welded on the fender connected to the wheel axle.
2. Heavycycles stage I tallight which i ever so lightly raised above the fender
3. Seat pan made by me with my good Moroccan friend laying the leather.
4. Quickly attachable passenger seat which took 2 days of heating up and beating with a hammer and 2 months to figure out how to do it.
5. Kellermans micro DF turn-signals mounted on the shocks
6. WP rear shocks
7.BST rims with Metal-Composite rotors
Sanctimonious
Discussion Starter #4
MY CROCODILE NIGHT ROD SPECIAL CUSTOM
CUSTOM PARTS
1 SUPERTRAPP EXHAUST END
2 SUPERTRAPP DISCS-END CAPS
3 LEATHER SADDLEBAGS
4 RIZOMA TRIPLE TREE
5 CUSTOM CHROME STOP LED
6 VRSC 1250 CLUTCH COVER
7 VRSC 105TH DERBY COVER
8 HARLEY 105TH MEDALLION X2
9 VRSC SMOKED TURN SIGNALS
10 KURYAKYN SWITCHBLADE PEGS
11 KURYAKYN MINI BORDS
12 SLIDER DUST COVER
13 CHROME RADIATOR TRIMS
14 CHROME COOLING HOSE
15 CUSTOM MADE FENDER
16 CUSTOM MADE AIRBOX
17 CUSTOM MADE SIDE COVERS
18 CUSTOM MADE FOOT LEVERS
19 CUSTOM MADE RAISERS
20 HIGHWAY HAWK HANDLE BAR
21 CUSTOM MADE HEADLIGHT COVER
22 LINES-CABLES
23 CHROME BOLT COVERS
24 SUPERTRAPP SCREWS
25 VRSCDX WINSHIELD (NOT IN THE PICS)
26 SKULL-WINGS MEDALLION
27 SKULL MEDALLION AIRBOX
28 NIGHTSTER WING BOOTS
29 DDM LO/HI 35W-6000
30 SKULL MEDALLION SISSY BAR
31 AILERON GRIPS
32 DOCUMENT HOLDER
33 HARLEY VRSCF LOGOS
34 CUSTOM MADE TOURING SEAT
35 FULL LEATHER COVER BIKE
36 CUSTOM MADE FALLED DOWN SISSY BAR-PASSENGER BACK
37 LEVERS-BARS PAINT
Just simple stuff, Custom paint, shield, chrome switches and levers, custom horn and cover, stainless where possible, seat, covers, shocks, UE tank. All tweaks by me, any drilling, filing, cutting or changing, by me. 2006 VRSCD.
Basic stuff but everyone stops and looks!
Vendor
What a lineup!
Lux you did a great job with the posting and the whole contest overall :notworth: Thanks again for doing this :cheers: One quick question did I miss the part where the 50 word limit was removed for this portion of the competition???? :hidesbeh: I left a lot of info on the edit room floor to make the 50 word limit...lol :D
Thanks again,
Bryan
brett
shite ,lux great job ,love the clip boards , this lots gunna take some time to sift through and pick a winner
great line up of bikes guys, they are all winners ,one way or another
What a great lineup and I didn't even vote for myself :D I knew this was going to be the best month....everyone was saving the best for last :notworth: Nice work guys :notworth:
Vendor
Thanks again,
Bryan
:them: I would have added a lot more to my description also! HA Oh well thanks Lux u did a bang up job posting all year long.
LOL, I thought the same thing. Lux really, Great Job, every month!
I will say, this is a fine line up (missing a few notables; Lonnie, Ron) and I'm glad to be along side such great bikes.
Sanctimonious
Discussion Starter #11
Thanks again,
Bryan
Esh I didnt realize that one was so long, I was just copying and pasting everything I could to get it out in time. Anyone want to add to theirs I will gladly add to their description. Just email it to me ASAP at [email protected]
brett
hey lux ,sorry im being a peanut now , can you refresh my memory is this a photo comp or a bike comp,only cos im torn between 2 bikes ,grrrr
Fah q 2
i think i picked the wrong month to enter,
Scott's bike is kick-ass, i rode it, and he's responsible for alot of things on mine.
there's even franks bike,
these are custom made vrods.
hats off to you people.
great job
and i am not sure who to vote for
Absolutely not :D Just thought maybe I missed something where you extended the limit to allow for all the custom mods to be listed. I'm glad you took this over and if you decide to do it again maybe for this portion of the contest only you could limit it to 100 words or something like that so the mods can be listed in detail :D
Thanks again,
Bryan
INCONCEIVABLE!
WOW!
What a line up ... very tough choice this month!
REVOLUTION !!!
Man, them are some real beauties... Gonna take a bit of time to look em over and choose just 1
:notworth::notworth:
PS - I do have it narrowed down to 6 at this point !!!
Definitely some nice Screensavers here..
Registered USDA
Great job Lux! Some friggin sweet rides. Makes me feel like I didn't do shit to mine.
WOW!!! just can't decide quite yet... I've actually seen Scott's up close in personal at the Polaris QSL. This month's decision will require many CCs of alcohol before I can vote.
Gone
I can't believe I've never seen some of these bikes before. This site is festooned with 500 pics of my non custom, bolted together bike. You bastages need to be posting more pics. Very nice bikes and some serious customs here.
Frank
If you go to the V-Rods and Hotbods II event tomorrow at Republic HD in Stafford tomorrow, you will see a couple of mine along with serveral others from the Forum.
1 - 20 of 54 Posts
