Which system is best?
  • Air Shifter
    Votes: 21 41.2%
  • Electric Shifter
    Votes: 30 58.8%
1 - 20 of 64 Posts
I FINALLY GOT BOOST!
So what do the experts say are the pros and cons for each?
Frank
Unless you are going to consider the V&H Servo Technology (~$1200) electric shifter, is air all the way. Of course you still should be running an electrc solenoid to activate that air cylinder!
Part-time mod
I saw that thing...very nice! Just hold the button and go, automatic shifting...wow!
I'm with Frank...but the ones available today with the elec solenoid are referred to as "electric over air"....Pingel has a couple they offer....the one you're after is the "junior" model.....alot smaller physically, 1/4" air lines instead of 3/8"......and plenty of power to shift the VRod......a smart addition for a street driven bike is the on board air compressor as well......
Isn't that called cheating?
Hmmmmmm maybe I could work something out with some sort of switch to use my air ride compressor for that.
Frank
On my 'B I have an air compressor on-board and I use the swingarm as an air tank. Both the suspension and the shifter run run off the air in the tank through seperate solenoids. I just use a toggle switch to add air to the tank whenever it gets low.
That is why you are my hero Frank. You have all the answers!!!!
As usual, I am gonna go against the grain. If this is for a street bike. Go with the Pingel electric shifter. They have done major improvments and decreased the piston size also. No hoses,compressors, airlines,airtanks,etc. It can also be wired to a shiftlight. To become automatic up shifted.
Bone Stock B Model
I agree with Joe here, if its just a street bike the new pingel electric shifter would be the way to go. If your gonna do any racing I would say air all the way.
Don't forget if you have the change Vance and Hines has the new electric out, for the street it looks like it might be a sweet ticket. It even allows things such as selecting neutral .
JeffC 1/2 to 300mph!
The Vance & Hines looked nice and Blake(?) talked me thru it's operation.
There are several of us riding around with non-working Pingels, hopefully when I get the chance to pull mine back off Pingel can get it to work.
Max, That setup is way over priced. It is very weak looking and I wouldn't want a fellow member to be the Guinea pig for them. Did you see how they mount it? I just wasn't very impressed. Different strokes for different folks.
Bone Stock B Model
The Vance and Hines one looks very nice. It also has a built in 2 step.
You have the old version!
If you use the 2 step feature. You need to machine your lever and control housing for a microswitch or use a destroyer clutch housing with the switch.
Joe I agree it is pricey but it is a track and ball system and not a solenoid like the others. The mount was terrible I agree. A custom mount shouldn't be a big deal.
As far as the pingel goes I know that early on mine dealt me problems but they did in the end get me a new kill module that corrected all the problems I had and for the last year mine has worked flawlessly.
If you race I think air is the best option, the electric is just handy for the street since it requires less maintenance to operate.
Part-time mod
Soo, what if you want one that's streetable AND track worthy? I'm not talking "Mike Lewis or Smoken Joe trackable", but just "having fun/test & tune night with maybe more potential" type set-up? Am I reading right that the new Pingle electric might be the way to go?
The Hawk
I am running the Pingle all electric and have had a few issues but got them worked out and it has worked well this past year, on the street and the track.
I use mine with the VRFID to trigger the shifts at whatever rpm I want and it goes down the track like an auto trans, let out the clutch at the start, nail the throttle and hang on.
Mike
1 - 20 of 64 Posts
