Max said:
Here is the pdf that explains all the changes..
Thanks for the link - and thank your source for providing the document. Its information like this that really sets the forum apart.
A couple of observations from reading the *pdf:
1) It looks like it is cost-prohibitive, if not to say physically impossible, to field-upgrade a bike to include the ABS system. In addition to the different calipers, wheel bearings, and ABS control module - you would need a different wiring harness. It also looks like servicing the brakes is becoming something best left to the dealership - apparently the Digital Technician is required to service the ABS system.
2) They have changed the crankcase breather tube to provide a better seal. Obviously some of the griping about odd oil leaks at the top of the engine prompted this.
3) I see that they have done away with the automatic compression release on the cams - the new, larger battery on 2007+ models permits this.
4) They have moved the voltage regulator to the bottom of the radiator shroud. While the VR is a sealed unit, this does place it in a location where it is more likely to get sprayed with water coming off the front wheel. Anyone have any thoughts on this?
Thanks again for providing the *pdf, Max.
