I've become a victim of aftermarket parts again.
The rear pulley I got with my Hogpro "six pak" wheels is wearing out. I have about 5000-6000 mis. on it. The belt is squeeking and the teeth are starting to square off.
I guess this is a common problem on aftermarket pulleys.(Honest shops will confirm this.) PM is starting to anodize theirs but Harley's hard chromed cogs seem to work the best. Most non-OEM are just plain Aluminum.
I can get a replacement aftermarket pulley, then get it powder coated, pinstriped and installed...$400-600 if I do it myself. I figure this will occur about every 10k mis. Great...
I've researched ways to get pulleys hardened or repaired and found Phil at SuperMax belt drives.http://www.supermax.net/Pages/home.asp He retrofits pulleys with polyurethane cogs and says they last indefinately.(some out there with 300,000 mis and still going) cost:I think around $400...ONCE!
The problem is he only does 70 and 65 tooth pulleys. He says he has received a few calls about v-rod pulleys but isn't sure if it will be worth the tooling issues. (read:is there a demand?)
Has anyone else had this issue? Is there another option for a long lasting pulley besides ugly ass MoCo stuff?
Maybe if there is enough interest from the members here Phil would get set-up to fix our stuff.
