I've seen several posts asking about adding ABS, but none cover the details. I fully agree that it may be wiser to trade in and buy a new bike, but I don't have a V-rod yet.
I'm currently looking for a salvage V-rod for a project so relocating the battery or other parts isn't an issue since the frame will be modified. I'd thought I'd ask before spending some quality time at the dealers parts counter cross checking part numbers.
Does the ABS use special brake calipers and discs?
I'm assuming special brake master cylinders that work with the pump. Or, is the ABS pump an in-line assembly that uses the standard master cylinders?
Can you add the sensor and magnetic wheel bearings or are the wheel hubs special?
Do you need a special load or a new ECU?
Several posts indicate that ABS bikes use a special wiring harness. Is this true? This seems odd since having a special harness adds to the assembly and logistics burden.
Granted, ABS is only needed in an emergency or panic braking situation. Yes, I've locked the front when I wasn't focused on the traffic and was able to release and reapply without harm, but ABS is a good safety item.
Thanks in advance,
Rob
Thanks in advance,
Rob
