I already paid for it, so unless there is solid reason not to, I'll test it.
And Yes; I don't understand.
What could be the orientation issue? Other than top up, wet hoses to the correct locations, and electron flow to the correct locations I don't see an orientation concern except momentum. The V-rod unit faces the direction of travel and the touring model is mounted sideways to the front.
If this is the issue, then I can mount it with the same orientation inside of the fairing. This isn't for a replacement of a defective unit, this is a new install. Mounting and location are undetermined at this point.
All things being equal, it appeared that the units were functionally the same, so getting a slightly used 08 item for $200 instead of an out of the box 08 one for $800 is way I got it. This being said, if it won't work I'll get the other one, but I'll install and try it first.
