I recently put new bars on my 2016 NRS and it was all good,
But yesterday the abs light went off, then came back on again, not sure if it was just a coincidence about the bar swap.
I can’t seem to figure out exactly why it’s coming on, I havnt had the back wheel off of touched anything in the rear of the bike but it’s throwing a rear wheel speed sensor code ( C1034 )
Anyone have any suggestions on what it could be, as everything seems to be working as normal.
I’ve checked for kinks and unplugged wire for the ABS cable and it all seems fine.
Anyone have any suggestions?
Thankyou-Ash
606517
Code is for rear ABS sensor. Check the plug connector and wiring from sensor to the Control unit.
The plugs are all secure and attached,
I changed my bars and cables so I had bleed all the lines ect,
Would air in the front brake line cause that code to be thrown, cause that’s the only reason I could think for a code to be thrown,
Cause everything looks fine on the bike?
UPDATE:
Seems to be good at the moment, light went off and didn’t come back on, I just unplugged and plugged the connections back in.
