Ok, it's a 2007 Street Rod. I have installed XR-1200 wheels on the bike, with VRSCX/VRSCAW wire wheel front rotors front and back. The front was a simple bolt on with a stock XR-1200 front axle and spacers. The rear was a spacing, gearing and belt length nightmare.
Anyway, I have long ago solved the infamous loose steering head bearing clunk and the bike has new head bearings torqued to the tight side of the fall away adjustment. I do this myself.
A couple of months ago I noticed when braking hard that when the fork compressed about 2/3 travel one could hear and feel a pronounced metallic knock. There was a sharp jolt in the handgrips too. When accelerating afterward and the fork extended you would feel another clunk in the handle bars. I took the bike to the dealer who put some fixed rotors on the wheels and said the problem went away. They wrote it off to a shift in the floating rotors on hard braking. Ah, so. I was $160 lighter for my effort. I have the extended warranty but because the wheels and brakes were modified no warranty. That part seemed fair at that point.
Two weeks later, after a hard run in some Sierra Nevada canyons and a fast run to San Jose the clunk occurred on rippled or broken pavement even with no brake application. It feels and sounds exactly like really loose head bearings, but again the fall away is on the tight side and there is no notchiness in the head bearings.
So, I put the stock wheels, brakes, axles, spacers, etc., back on and there was no change. Now the bike is back at the dealer with all the stock parts so they cannot blame anything on me, but the techs are stumped. One suggested it may be loose pads in the caliper but I do not buy this. I have some Brembo racing calipers and floating iron rotors on another bike of mine, no anti-chatter spring in the caliper at all, and the rotors and pads jingle like a Ducati dry clutch from engine vibration at a stop light and even at low speeds on bumps, but it never feels like the clunk in my Street Rod.
My opinion is that there is a loose or worn part inside the fork, perhaps a bushing is shot or the screws holding the cartridge or damping rod to the bottom casting has come loose but so far the dealer tech claims all is well.
Anyone ever been here before? This is my first bike with cartridge forks. I'd like some ammo when challenging the diagnosis of the tech if the need arises.
