1 - 12 of 12 Posts
So I bought a used power vision from the board and got my license from Fuel Moto. They sent me a tune to match my bike with the license. My only mods are a K&N filter and Akrapovic exhaust - 2009 VRSCF.
I installed the exhaust and flashed the ecu yesterday and rode to work this morning - I noticed I was using a ton of fuel pretty quick, I started with a full tank and 36 miles later when I got to work I had less than 1/4 tank left. I also looked down on the interstate and the front header was glowing red. I’m assuming it’s burning the extra fuel in the pipe? No popping or other bad symptoms that I could tell. When I it off the interstate the pipe didn’t glow as much, but could still tell it was a little red right by the head.
I’ll call Fuel Moto Monday, but do you guys think I’m safe to ride home? And is there anything I can double check to make sure I didn’t do incorrectly?
Thanks
36 miles and quarter tank doesn`t sound unusual . I get about 120 to 140 on tank . Plus who knows if your gauge is accurate .
Sorry, I meant there was less than a quarter left in the tank - so I used over 3/4 of my tank in 36 miles. I had filled all the way up before I left.
glowing headers
Oh yeah u need to check the settings before u damage the engine. Thats way to much fuel, hell u might want to change the oil once u get it straight. I understood your first post and u are right to call moto. I would not ride it far again until I know problem is solved.
Sorry read it wrong . Get it cheeked and like a poster mentioned check your oil . I would not ride it .
Discussion Starter #8
My wife’s bringing the PV up to my work and I’m going to flash the original and see how it does on the way home... thanks for the suggestions
Well? The rest of the story.................
Discussion Starter #11
I need to finish testing, but here’s where it is now. I flashed the original tune on it in the parking garage at work - when I turned the ignition on to do it, my gas gauge went up to just over half a tank. The gauge had been wonky when I got it, but I let seafoam sit in a full tank for awhile and it had been working fine for months. After the reflash the ecu resets and it went to almost 3/4 of a tank.
I checked the oil and it was fine, and I had been reading all day about the glowing pipes and it went back and forth on people saying that with a thinner single wall pipe on the Akrapovic it was normal, and others saying it wasn’t - but none of them had the Akrapovic pipe. Since I was on the original tune, I started it and let it idle and since it was dark I could start to see the pipes near the head looking red when it got hot. I rode extremely easy next door and filled up the tank and then rode back to the gas station by my house and filled up again to see how much gas I had used - 0.9 gallons in 36 miles so I know on the stock tune I’m not dumping fuel.
I want to test the same thing on the tune from Fuel Moto, but first I want the PV mounted so I can set the digital gauge function to display my engine and coolant temps, real time mpg, etc. So since then I’ve been making a mount for the PV, flipping my mirrors to under the bars instead of above since I had the front panels off, and making a new bracket so I can use my windshield with my headlight cowl on.
I should be done with all that stuff today, but it’s raining here the next couple days so I won’t be able to test it right away.
Was there any fixing it ? I have the same problem with the same exhaust. I just spent the money on the PV an the target tune but they have not sent me an email yet. My exhaust glows cherry red an piss poor fuel.
1 - 12 of 12 Posts
