1 - 20 of 31 Posts
I know this is going to fly in the face of everything I've read here, but I thought I'd share my experience.
I bought my bike (2004 with 1250 SE upgrade, SEII cams, 58mm throttle, V&H 2-1) with a 28t already installed. I've never been happy with the bike. It just always seemed to be geared too short. I'm completely with the crowd that thinks this bike needs a 6th gear or higher 5th.
Since it's just a quick sprocket change, I decided to try a 30t. Much to my surprise, I now understand why that's the size harley chose from the start (and stayed with in Europe). I find the bike to be MUCH more "usable" with the 30t. It's just a world nicer to ride. I now feel like I'm in the right gear when cruising. A subtle change but significant in the real world.
Is it slower? Who knows. It's still faster than my buddies Street Glide, still slower than my Honda and I can still roast the rear tire from a stop. I've not stalled it once or felt i was at risk for stalling.
Just personal preference, so not putting down the other opinions posted on this board. We all like what we like. I just wanted to post this for anyone who finds themselves in the situation I was in.
I've been wondering about this.
It could use a 6th gear or a taller gear ratio in 5th. To me 4th and 5th are so similar.
But doing it at the sprocket has got to rob some power out of them all.
U don't notice a difference?
"Vrod King"
The 30T sprocket is a very good way to go for the highway. I still have that on my '02 and it gives me way better gas mileage too. My other two are set up with chain drives and are straight city (light to light) rides. If I was too start riding the two with the chains on the freeway, I would be changing the rear sprocket to a smaller one in a heart beat.
This bike needs the 6th gear like my son needs another Lego set.
5th is absolute perfection on US highways, unless you ride at 100PMH for long periods of time. Increasing the start of powerband (5K RPM) in 5th from 80MPH to 87MPH AND making it more sluggish off the line?
That's what the Honda Shadow is for.
Asatruar
:notworth::them:
REVOLUTION !!!
I enjoy my 30t once I am rolling along but don't care for the slow winding up in First gear and slipping the clutch to get started especially when 2 up. Love the 26t for stoplight to stoplight action.
VRSCF
Im in the UK (still part of Europe) and we get the 30t as standard. The best upgrade I ever did was fit the 28t. It feels perfect for the engine and my riding style :)
....everything is relative I guess !
Are the US bikes 28 on the back ? Where can I get a 30 size sprocket and belt ?
Asatruar
Early US models were 30 tooth FRONT sprockets. By 2005 (?) they were 28 tooth.
Rear sprockets are 72 tooth.
Cabeca de Ferro
Don't forget to adjust the speedometer ratio.Mine is an 06 with 30T ,when I have installed the T Max it cames with the US speedo ratio_On a trip of 1200 miles my speedometer has shown me only 1000 miles run.
30 tooth or 66-68 tooth or chain & sprockets here I come !
All I can say is yea, I'm tired of shifting into 5th again. My 900cc 3 Cylinder 5 speed Triumph had the same issue, I just got a back sprocket with 3 or 4 teeth less, shortened the chain - it took the bite out of the RPM at 75 but the engine was still ready to pounce for a pass - was it a 6th gear ? no, but for $ 65 who cares - it fixed the problem. The V Rod has a relatively large amount of weight to get going, and a relatively close 4th and 5th gear, I'm sure designed for 1/4 mile trap speed and RPM. The 30 tooth would probably be perfect for me - and don't forget it allows better use of the torque on tap rather than revving out prematurely in each gear, and top gear. I love my R model but it's really an issue of urban bike vs longer trip bike. Identify your mission, gear appropriately. Even with a 28/72 tooth I figure my bike is good for 140+ MPH, from 70 MPH to 110 MPH + 2 up happens PDQ, so its about lowering RPM and increasing mileage on longer trips. Why someone does not make a 66 or 68 tooth rear pulley is beyond me - that back pulley is too large in diameter, blocks the view of the wheel, weighs like a 10 lb boat anchor. I guess the fix is fit a chain and sprockets with the right ratio, $ 550. Oh, and a can of chain wax $ 12, and spray every 200 miles. Oh and clean off all the chain lube spitzle - 2 hours every 200 miles. Or just fit a 30 tooth, call it good. :blahblah: :D
This bike needs the 6th gear like my son needs another Lego set.5th is absolute perfection on US highways, unless you ride at 100PMH for long periods of time. Increasing the start of powerband (5K RPM) in 5th from 80MPH to 87MPH AND making it more sluggish off the line?
I think people just like to shift or are used to having a sixth gear. Personally the gear-box is perfect for a multitude of scenarios with the 28. From street to track.
The OP has engine upgrades and possibly that affords the bigger gear. However the 30 is tall for city riding and will cost you in the 1/4 mile and light to light action. 2-up with a 30 has to be a pig.
There are dozens of threads and posts here that well document the 7% change from 30 to 28, 28 to 26 and visa-verse, a 6th gear would do similar retaining the ratio. 7% is roughly 500 rpm's. Hardly worth the effort.
You can adjust speedo in the T Max software
Shelby Stanga Rocks
Now that we are beating the dead horse again...I will add my two hits.
For most if not all who want a 6th gear or who swear by the sproket change its all mindset. Drive a Small Block 4 speed 55 Chevy will 4:88s and a 28 inch tire. Talk about hiway...dont worry ya get used to it 4000-4500 @ about 70MPH. So maybe thats why I am comfortable with the current REVO ratios.
This wouls be so simple if it were shaft drive, no arquements on ratio. LOL
30T is standard here,I ride a lot 2 up and never had a problem with stalling the bike but my girls weight is only 50 kg..and I still beat a CVO with a passenger on my v rod lol
I have a 28T and matching belt in the garage for summer time when my tyre has more grip and drift through the corners,that's the fun part of the 28 :)
1 - 20 of 31 Posts
