Hi guys, I just installed a Fitzgerald 26T front pulley on my 2005 VRSCSE and ran it's first 150 miles, noticed the belt is suffering some erosion on it's outer border for what I can see, check pics below. The tension was properly adjusted as per manual at 6mm deflection with 10 pounds pressure unloaded, straight and un-jacked. Is that kind of normal while the belt "gets used" to the new pulley or the outer lip of the pulley is just a mm too close in? Thank for any help gentlemen!
