1 - 17 of 17 Posts
Current set-up is 200 Avon on a stock 5.5" wheel.
On Right is new 240 Avon on Kosmanized 8.5" wheel.
My narrowed pulley comes back from the polishers next week.
Still need compensator bowl ,bearings, and rotor and wheel bolts
Does it fit under the stock fender or will you have to change it?
CHROMENATION
It fits under the stock 180 fender , it actually makes the tire look wider/bulkier under the stock fender i.m.h.o.
Bad ride inside
sweet it will look awesome i did this a little while ago and never looked back
So can you break this down as to what you need for the complete setup? All the swing arms I have looked at are over $1000 just to start with.
Can you post a link to there website or contact info plz. I have the 21mm belt from a 06se on a 07 belt and would like to close the gap...
1 - 17 of 17 Posts
