2003 vrsca
I’ve had this 240 for 2 years, I want it on... Can anyone point me in the right direction as of to where to purchase the narrow belt??? Doesn’t have to be Harley... Does anyone have a 07-16 swing arm and rear axle with it for sell??? It seems to go with the 07-16 swing arm is a lot easier than keeping the stock swing arm... Any help is appreciated...
Yes Harley parts.
149 tooth... 40627-06
150 tooth... 40658-06 ... not sure this is still available.
Not hard with stock swingarm..
Text Line Handwriting Parallel Notebook
The 150 tooth belt is no longer available, and hasn't been for years. I have heard of having the wide 150 belt cut down and narrowed to size.
Ok, if you decide to go to the 28 tooth pulley, check and see if the pulley hub needs to be changed. I'm not positive but if I remember there is something about '03 pulley hub change for pulley exchange.. Search it first.
2003 vrsca
You said if I “decide” to go with 28t pulley... What is it that the front pulley needs to be changed???
2002 and 2003 had a different output shaft flange that the pulley bolts to. You need to xhange the flange to 2004 and up in order to switch to a 28 tooth front pulley.
