1 - 3 of 3 Posts
Im installing a Altered State side mount plate. Great product and very well made. I have ran the wires up to under the passenger seat.
I forgot to make note of what wires used to plug into the old plate. I also installed a fender eliminator kit.
My issue is now I do not know where to splice in the wires for the plate. Can anybody help please.
Thank you
Thank you
The license plate light wires are in 6-place "multilock" connectors. These connectors have male pin terminals on the bike side and female socket terminals on the component side with the following numbers/wire colors/functions:
1 / blue wire on bike side; black wire on component side / from LIGHTS fuse to license plate lights hot
2 / black wire on bike side; black wire on component side / from license plate lights ground to ground on front cylinder head
3 / brown wire on bike side; violet wire on component side / from turn signal module pin # 6 to right turn signal hot
4 / black wire on bike side; black wire on component side / from right turn signal ground to ground on front cylinder head
5 / violet wire on bike side; violet wire on component side / from turn signal module pin #5 to left turn signal hot
6 / black wire on bike side; black wire on component side / from left turn signal ground to ground on front cylinder head​
1 - 3 of 3 Posts
