Hello! Ive been scrolling through the forums and have not found a thread pertaining to the issue I'm having with my v rod. I have a question that hopefully someone can answer for me. Recently I changed my handle bars from the stock bars to 18" ape hangers . I extended the wiring and also installed new grips with the turn signal lights built in on the ends. Upon completion of the wiring I checked my work and noticed that the switches work but the bar end turn signal lights don't. I checked voltage going into the turn signal module and was at 12v. I Checked voltage coming out of the module and it was 13-15v which was odd to me. Could the module be internally shorting to pwr? Also I should note that the new turn signal lights are not L.E.D. and the stocks turn signal lights were. Would this cause a issue as well? I would greatly appreciate it if someone could help me out on this issue.
