1 - 2 of 2 Posts
got this 2007 vrscx bike origional bottom end let go,guy bought a 2013 muscle motor and jammed in it. all hooks up the same electrical connections all identical . hit the button instantly fires for 3 seconds and quits ,lots of fuel pressure ,spark, thinkin maybe the ecm is different for the muscle. have swapped crank censor,throttle body ,injectors off old motor still nothin. anybody have any experience with this swap or have a idea whats up
I just looked on Ronnies HD at the part numbers. The ECM part numbers for both years are the same, but they have different notations and both state that they need to be flashed when installed.
For 2007:
604801
For 2013:
604802
I am guessing that you need to have your ECM flashed to match the new motor.
I really wonder if one of those Cobra auto tuners would do the job. Don't they override the ECM, or do they work in conjunction?
I will be curious to see what you come up with. Isn't that the 1250 motor? If so, you should get a descent power up.
1 - 2 of 2 Posts
