Is there a specific brand that's better?
Not really when it comes to the clutch. Braking wise, Syn Dot4 will handle more heat if racing but all Dot4 brands will start lose the anti corrosion additive in around the 2 year period and should be flushed and replaced with new, especially with ABS. The ABS module also needs to be cycled to do it correctly. Clutch, just a simple fluid swap.
Motul 5.1 is what I use and sell. Overkill? Maybe. Cheap piece of mind (and it doesn't seem to leave the white crystalline residue in the clutch reservoir).
