1 - 3 of 3 Posts
I have bought an older style tts supercharger(filter faces in towards front header)
It was off a 2006-9(not quite sure) v rod
I have a 2012 NRS
All has fitted up well but coming to the thundermax and 2 bar map sensor.... thundermax is a 309-340 with auto tune added which i believe makes it a 309-350.
I dont think this unit is compatible with the 2012 model(i could be wrong)
I am thinking of getting the thundermax with autotune then adding the 2 bar map sensor that i got with the bike.
Is this the way to go? and how would i go about getting a map?
ps im in australia
Many thanks
There is a drop in MAP sensor that I think Bosch made. Jan-Dirk did the post years ago. You can get it at any parts store. I feel it may have been a 3 or 5 bar sensor ( you'll want the headroom). Call Trask, they have a base map they'll email you. Make sure you have an upgraded fuel pump and that your injectors are properly sized, stock & even Destroyer stuff is WAY too small. You can find calculators online.
1 - 3 of 3 Posts
