Hey all I've just fitted a 2into1 Akropovic exhaust and a k&n air filter with topless airbox. No tuner. I took it up the road but it didnt run well as it hesitated and so on. Question is can I replace the filter back with my stock filter and use the bike till I get a tuner? Its fitted with factory NB 12mm at present. Cheers
Def need a tune. Make sure the 12mm sensors are not shrouded by using the reducer bushings from 18-12mm. Better sampling that way for tuning if you chose NB sensor tuning. Breather element won't make any difference regarding your low end complaints.
"Grab your ankles"
As others have said, you NEED a tuner. Get in touch with FuelMoto.com and they will get you hooked up. They have a database full of tunes for just about every mod combination imaginable. Call them up, tell them your mods list, pick a tuner, they'll load it up with a tune file and put the tuner in the mail. Easy as pie. Good luck!
My Last Ride
Typically people install custom exhaust to increase torque and horsepower. More power requires more fuel.
