I'm going cross eyed looking for this. does anybody have a map for tab slip ons and hi flow air filter. I have PCV and I'm running the Powercommander map for that set up. It back fires and pops a lot on decel. Any help is appreciated.
Thanks.
Look under my profile. I have posted numerous maps and so have others. The big problem is you can only post the maps/files once unless you keep changing the file name.
Here is a link to a couple
http://www.1130cc.com/forums/showthread.php?t=139413
http://www.1130cc.com/forums/showthread.php?t=145379
http://www.1130cc.com/forums/showthread.php?t=141508
Please realize that these maps are only a starting point and will need to be adjusted to suit your particular setup or riding style.
By the way welcome to the 1130cc.com. Please I know there is alot of reading and BS to sort thru but we keep adding more and more threads about the PC V only hurts us more so then helps. So please try to work the search function before starting a whole new thread, per reason stated above.
When I put on my airfilter on and went topless there was little to no change required. My biggest changes came from exhaust install.
Thanks man. those threads are a huge help. The search function is hit and miss on this forum ( as it is on all forums) lol.
As you will find the "F" seems to be a little bit of a BI$%^ sometimes to tune. Come back often and try to helps us by keeping to one thread. I know dragging old ones back up is sometimes redundant but it makes it easier for us to know what you are working from.
If you need extra help PM me. Bored right now. Bike parked and sled's parked for a bad cooling hose.
Flat Broke
Thought I would add my current map. It is the one for Tab 2.5" baffle slips with some slight adjustments to some of the higher fuel additions. Still runs a little rich but the decel pop is much better.
