All,
I've spent the last few days searching through these forums for the appropriate map for my 2009 Muscle.
I'm swapping out my stock header with Tab slip ons for the V&H 2into1 comp header/exhaust. Currently, there is a PCV installed.
Everyone points to Phoenix 2012.pvm
Is this still the recommendation?
I also noticed that the previous owner unplugged the 02 sensors. I assume that the PCV requires that. I've ordered 12mm bung plugs for the v&h headers.
Is there anything else I should be aware of?
Assuming all goes well, I'll have a set of Tabs available.
~jdubsweb~
I would load the one builtin, which is also on their website for the 2008 family (non-muscle)... see how it runs... then use the autotune.
Their support will also sit on the phone with you, help select a tune, and stay on the line until it loads.
thanks for the recommendation
Santego - I've come across several of these forums that say the M15-006-005 runs terrible.
As I mentioned, I only have the PCV with no o2 sensors. Therefore, I can only assume an autotune option is out of the question.
Great idea to look outside the muscle for maps though. I hadn't thought of that.
I have a 2015 with a K&N filter and full Akropovic exhaust. I used the closest tune they had, then ran Autotune twice with stock sensors. Bike runs amazing... and my friend has the same bike with slip-ons that i can swap to compare.
Before the full pipe and tune you couldn't tell whose bike you were on... afterwards... huge difference. so I have been happy.
