105th
Everything you ever wanted in a big, luxurious touring motorcycle – now with just a little bit more. The Ultra Classic® Electra Glide® model provides the ultimate in touring comfort and performance. An 80-watt/amplifier, Harman/Kardon® Advanced Audio System. Vented lower fairings with integrated storage compartments. Luxurious comfort-stitch Touring saddle and passenger backrest. The smooth-shifting 6-Speed Cruise Drive™ transmission. And much more.
Plus, for 2008, the Ultra Classic Electra Glide model is available with factory-installed Brembo® brakes, with optional ABS. A six-gallon gas tank and adjustable right and left fairing-mounted air deflectors are also new for 2008. The best part is, it all comes standard with the undeniable sound and feel of the Twin Cam 96™ engine. In other words, it’s 100 percent Harley-Davidson.
The 2008 Ultra Classic Electra Glide model is available in serialized, limited-edition 105th Anniversary styling, featuring special Anniversary Copper and Vivid Black paint, a tank cloisonné with Copper Bar & Shield, a copper vinyl insert on the seat and pillion and more.
GENERAL INFORMATION
Manufacturer Harley-Davidson®
Model Year 2008
Model FLHTCU Ultra Classic® Electra Glide® 105th Anniversary Edition
Price * Request a Quote
Color Copper/Black
Stock Number: 101
Miles/Hours N/A
POWERTRAIN
Engine Air-cooled, Twin Cam 96™, pushrod-operated, overhead valves with hydraulic, self-adjusting lifters; 2-valves per cylinder
Displacement 96 ci (1,584 cc)
Bore x Stroke 3.75 x 4.38 in. (95.25 x 111.25 mm)
Compression Ratio 9.2:1
Torque 92.6 ft. lbs. (125.57 Nm) @ 3,500 rpm
Fuel System Electronic Sequential Port Fuel Injection (ESPFI)
Exhaust Chrome, cross-over exhaust with dual mufflers and taper end caps
DRIVETRAIN
Transmission 6-Speed Cruise Drive™
Clutch 9-plate, wet
Lubrication Pressurized, dry-sump
Final Drive Belt, 32/66 ratio
DIMENSIONS
Frame Mild steel, square-section backbone with twin downtubes
Length 98.3 in. (2,496.82 mm)
Width 39 in. (990.6 mm)
Height 61 in. (1,549.4 mm)
Wheelbase 63.5 in. (1,612.9 mm)
Seat Height Laden: 27.3 in. (693.42 mm)
Unladen: 30.7 in. (779.78 mm)
Ground Clearance 5.1 in. (129.54 mm)
Dry Weight 814 lbs. (369.22 kg)
Fuel Capacity 6 gal. (22.71 l)
BRAKES / WHEELS / TIRES
Suspension Front Forks: 41.3 mm telescopic, cartridge-style damping; 4.6 in. (116.84 mm) travel
Rear Shocks: Air-adjustable; 3 in. (76.2 mm) travel
Brakes 32 mm, 4-piston fixed front and rear calipers, patented, fixed rotors
Front: Dual 11.81 x 0.2 in. (299.97 x 5.08 mm)
Rear: 11.81 x 0.28 in. (299.97 x 7.11 mm)
Tires Front: D402F NW (MT90B16 72H)
Rear: D402 NW (MU85B16 77H)
Rake 26°
Trail 6.2 in. (157.48 mm)
GENERAL INFORMATION
Model Year 2008
Color Copper/Black
Stock Number: 101
Miles/Hours N/A
POWERTRAIN
DRIVETRAIN
Clutch 9-plate, wet
DIMENSIONS
Rake 26°
