1 - 1 of 1 Posts
Ray Connor
Another project I will not get around to. This bike was wrecked and repaired and then after repaired it was found that the wheel was no longer true. I see no physical bend, nicks or dent in the wheel/rim. The bike was totally repaired and then upon test drive the bike began to shimmy in the front end around 45 mph. It just needs to be re-trued by someone that knows how to true a rim by adjusting the spokes. The wheel, tire, bearing, rotor, etc. only had around 500 miles on it and the tire still has tits on it. It holds air and seems fine. PLEASE REALIZE IT NEEDS TO BE TRUED. It has Brembo rotors, bearings, rim, spokes, tire, tube etc. and should fit on any V-Rod ever built since 2002. So if you want a laced front wheel here is your chance to get one cheap. I have no way to check the run out to tell you how much the rim needs to be brought back in spec.
1 - 1 of 1 Posts
